Terminator3
Advanced Member level 3
for example, in qucs simulator. is it necessary to have schematic device model, or it can be replaced by s-parameters for certain bias and operating point conditions?
thank for the reply. But also some small question to make things more clear. What if i use biasing for certain s parameters, so real value of current through biasing resistor is exact, it is still will be not useful to use S-parameter?
Also i want to ask this: there is device model schematic in some datasheets. There some capacitors, inductances, etc. with parameters. Is there any hope that using such schematic in free simulator like qucs i can get results that are not too far from reality? I tried to download spice models made for ads, mwo, spice etc. all paid programs and import that data into qucs, but it is not worked. file format is different, and qucs internal conversion utility gives syntax errors. So i want to draw this schematic by myself and do simulation, as i understand spice model and that schematic in datasheet is the same thing, right?
Thanks for the replies. Also i want to ask what is usual startup time of 2.4ghz and 5ghz oscillators? how much ns startup time is good, how much we need to simulate to see steady state?
What if harmonic balance gives no result, but transistent simulation works. What can it be? Wrong setup of hb schematic?
