ddt694
Full Member level 3
- Joined
- Dec 12, 2002
- Messages
- 170
- Helped
- 4
- Reputation
- 8
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 1,400
vcxo loop filter
I had designed a pll, the reference is a 10MHz ocxo, the FPD is analog device's ADF4001 pll chip, the vcxo(not a vco) output frequency is 70MHz, and the sensitivity is very low(5Hz/v).
The loop is very difficult to in locked, and the loop parameters are very surprising-- the feedback resistor is 12000000000ohm, the feedback capcitor is 14.1fF(what is fF?).
i suppose this is because the filter have to be high gain to compensate the low sensitivity of the vcxo.
i want to know, if the vcxo Pll is really difficult to be in locked? and what is the implementable method?
may be i should use a all digital pll, say, all the FPD is realized in a CPU or a FPGA, and the control voltage is generated by a DAC, the output of the DAC is tied to the control pin of the VCXO?
regard
ddt694
regard
ddt694
