Is Cadence SPB16 compatible with Vista?
Johnson
Advanced Member level 2
Is SPB16 compatible with Vista? I recieve this error message:
"The procedure entry point RWResetO2K3Colors could not be located in the dynamic link library RWUXThemeS.dll"
Any suggestion?
the procedure entry point rwreseto2k3colors
i am not sure with Vista but the same type of error i got in WIndows XP.
That time i set PATH environment variable to software /bin directorye.g.
variable : PATH
value : Install directory/Cadence/SPB16.0/tools/bin
you can try the same .
    Johnson
rwreseto2k3colors orcad
Still not fixed!
orcad rwreseto2k3colors
As i am kwon,it can install in the system of vista.although i have not use cadence spb16.0,but i see some messages about spb 16.0 installing in the system of visa on a very goog forum in chinese.
rwreseto2k3colors rwuxthemes.dll
It is fixed by reinstalling!
rwuxthemes.dll
A solution to start_error ‘The procedure entry point RWResetO2K3Colors could not be located in the dynamic link library RWUXThemeS.dll” is as follows:
I found that the System finds older/smaller version of RWUXThemeS.dll in c:\win\sys32, which has priority by coming first in the path string.
Rename c:\win\system32\RWUXThemeS.dll to RWUXThemeS.OLD.
Copy C:\OrCAD\OrCAD_16.0\tools\bin\RWUXThemeS.dll to c:\win\system32\
Adding C:\OrCAD\OrCAD_16.0\tools\bin\ to system path variable will work if it comes first in the path. It is good practice to have the path goto the c:\%systemroot% & c:\%systemroot%\system32 folders first, as so many references are made to these two primary system locations.
rwuxthemes rwreseto2k3colors
Some components cannot support vista on spb 16.2.
Re: rwuxthemes rwreseto2k3colors
I have a similar problem.
Done with installation and setting up the license.
While opening the tool it gives the following error.
Any clues???
Entry Point Not Found
The procedure entry point ?SetCpmHandle@CDSSmlLibReader@@QZEXPAX@Z could not be located in the dunamic link library cmpropertyserver.dll
Any help appreciated.
Thanks
