is cadence ic 5141 usr2 the latest release?
I believe they have recently released 5.2.51 or something like that (am not sure about the last number ... it is 5x). This new version is OA only (I am not 100% sure) so you need an OA PDK to make it work (unless you are planning ot create a PDK of your own).
IC5141:
LINUX RHEL 2.1, 20 Jan 2006 ISR200601181055, Version: 5.10.41.500.3.30
That's ICOA 5251
not IC5251...
so ic 5141 usr3 the latest release
Hi these are the till now releases for IC5141.
Have a look at it.
IC5141ISR12_sun4v_Del
IC5141ISR13_lnx86
IC5141ISR2803_lnx86
IC5141ISR2803_sun4v
IC5141ISR500_sun4vDel
IC5141ISR_lnx86
IC5141ISR_sun4v
IC5141_lnx86
IC5141_sun4v
IC5141USR1_lnx86
IC5141USR1_sun4v
IC5141USR2_lnx86
IC5141USR2_sun4v
IC5141USR3_sun4v
These are the Open Access release
ICOA5141Base_lnx86
ICOA5141Base_lnx86_dump
ICOA5141ISR023_lnx86
ICOA5141ISR_sun4v
ICOA5141_sun4v
ICOA5141USR1_sun4v
ICOA5251ISR_lnx86
ICOA5251ISR_sun4v
ICOA5251_lnx86
ICOA5251_sun4v
Hello the most update/patch from IC5141 is ISR200602222305, (5.10.41.500.3.32)
sorry to pop-up this very old post.
what is the most recently 5141 usr# ? anyone knows that ?
ic5141usr4 (for sun at least). there are newer ISR releases, but USR4 is the latest USR release.
IC5141 USR4 is the latest IC5 release for Linux as well.
Cadence has updated their license features. If you get the latest license from cadence, you should update your IC to IC USR4 or later ISR.
After our IT installed USR3 and renewed the license, we can not use the tools which our license should support.
Cadence field application engineer came to our office and found that the latest license does not support USR3.
So even stuck with 5141 but with its recently newer isr installed, the old license cannot work any more. Is this statement correct ?
