is anybody know brown out reset?
incol
Full Member level 2
Full Member level 2
can anyone help me?
thanks
IanP said:
Hre is a link to a short publicaton on reset issues:
h**p://ww1.microchip.com/downloads/en/DeviceDoc/31003a.pdf
That includes BOR ..
Good luck
thank you very much, but there isnt a particular circuit in it, could you tell me how can i get a more particular circuit, i want to design a bor circuit.
thanks
IanP said:
If you would like to design it by yourself, here is an example of a BOR IC:
MN13811 from Panasonic
(data sheet: h**p://www.alldatasheet.net/datasheet-pdf/pdf/PANASONIC/MN13811.html )
There you will find info on this IC, including its block digram, which can be helpful in your design ..
Good luck ..
thank you very much! but i found that all the circuit are using comparator, dose por must use comparator? is there any other circuit that dont use comparator, just some inverters(for example)? thanks
