IR2113 input logic level of0-5V
anotherbrick
Full Member level 4
Full Member level 4
Istanbul , Turkey
ir2113
IR2113 requires 0-15 V to LIN and HIN input
is there an upgrade of this component
with 0-5 V HIN LIN input ?
ir2113 minimum operating voltage
the logic input level for IR2113 is: "VIN Logic Input Voltage (HIN, LIN & SD) VSS - 0.5 VDD + 0.5, VDD Logic Supply Voltage -0.5 VSS + 20"
i took this from the datasheet, this means that id you want to drive the ic with 0-5V you need to supply Vdd pin with 5V.
please read the datasheet carefully and you will understand.
