TuralH
Junior Member level 2
- Joined
- Nov 18, 2024
- Messages
- 21
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 110
Hi everyone,
I’m working on assembling a DC-DC converter using the UC3843 in voltage PWM mode. I am using the IR2110 as a high-side MOSFET driver. The goal is to step down 60V to 12V, which will then be used to control a motor.
The issue I’m encountering is as follows:
- The circuit works correctly when the drain voltage of the MOSFET is at 30V. in LTSpice
- However, when I increase the drain voltage to 60V, the circuit stops working in simulation.
- At 30V drain voltage and 12V VCC, the gate voltage (HO) appears to be 42V.
- When the drain voltage is increased to 60V, the circuit no longer operates properly.
