DasPreetam
Hello everyone,
First of all, I'm a complete newbie in the field of microcontrollers. So please bear with me as I get familiar with the terms.
I'm trying to make a IR transmitter that will send a BCD code modulated at 38Khz carrier frequency.
eg :
When I press switch 1, 0001 is transmitted
When I press switch 2, 0002 is transmitted and so on.
I know that in order to send the signal, the carrier frequency needs to be modulated. I heard that microcontrollers are perfect for the job, but since I don't know anything about them. It's a daunting task for me, so it'll really help if you guys guide me.
Also, I saw that there are microcontrollers with 40 pins and then there are 16 pin also, for this circuit, I guess small microcontroller is needed (Because TV remotes are generally small). So which one should I use ?
eg :
