IR activated relay switch
Roelescence
Newbie level 6
Newbie level 6
I need a schematic for an interupted IR activated relay switch. Please help. I'm working on automation circuits
Thank you,
Roelescence
h**p://electroschematics.com/389/infrared-switch-operated-by-remote/
h**p://www.electronics-circuits.in/2012/03/infra-red-activated-power-switch.html
you can find similar schematics on the web
good luck hope these are what you are looking for
ah you want IR activated relay switch as the title said or something else be clear plz
You want to give some thought to -which- IR source
will activate your relay, and how to make sure the wrong
ones don't. Making an "anything works" controller is the
easy part.
A HF AC waveform and a frequency detector can let you
do things like rejecting sunlight and 60Hz lighting. At the
cost of some added componentry.
I want an IR activated relay switch for home security purposes. I want that once the IR is interrupted, the relay closes for at least 3 minutes or so. Will it work without microcontoller?
I got this diagram from google but I guess the circuit can only activate the relay for a few seconds. Am I right?
