franz53
Newbie level 2
IR2110 HI-SIDE auto-on problem
I made an inverter at 40Khz, full H-bridge using two IR2110 to drive four IGBT.
An identical configuration is just working perfectely at 25 Khz, 1.5 Kw.
I set a large interleave time between lo and hi side to be sure to avoid cross conduction given by the t_on t_off of the IGBT and I set a fix 50% duty cycle to be sure about the bootstrap charge timing.
The problem is that the hi-side goes on itself and this auto-on is syncronised with low side command in this way:
- LO-SIDE=0 / HI-SIDE=1 -> at the end of the ON period of hi-side, I see the gate signal goes ON again after few us. The gate goes off as soon as the lo-side command goes to 1.
- LO-SIDE=1 / HI-SIDE=0 -> at the end of the ON period of lo-side, I see the gate signal of the hi-side goes ON itself.
I try to midify the gate resistance (usually 10 ohm with a BA159 fast diode in antiparallel) but nothig changed.
IGBT is IXYS model IXGH20N60BD1 (with fast reverse diode integrated) and , on the paper, can normally work at this frequency.
I have this auto-on not always but only sometime and I can see that the output signal of the inverter is good.
Of course I must be care because the cross conduction can easily distroy the output stage so I must do test with low main voltage (i.2 50-60 Vdc instead of 310 Vdc from a rectified main line) but I found the auto-on signal even with this low main voltage.
Have you some notice about??
Thanks in advance
Francesco
P.S: sorry for my english .. is really bad!
Thanks in advance
Francesco
