IQ modulator DC bias problem?
cybq
Junior Member level 3
sz
I am now developing a project which involving a IQ modulator. The problem is the modulator don't work when the four I,Q inputs(I+,I-,Q+,Q-)are 1.5V DC bias at the same time. But it's clear that it work with all inputs 1.5V DC bias in the datasheet. Why?
The effective signal is than
V(I+)-V(I-)=0
V(Q+)-V(Q-)=0
so the modulator should generate no output signal. Only spurious!
How are you applying the bias to the IQ terminals? If you connect a 1.5VDC power supply to each terminal, the low impedance of the power supply will short out the signal coming from the baseband. You should scale your baseband D/A signal so that the average bit value produces 1.5VDC.
I bias the I , Q inputs with resistor voltage divider from 3V power supply.
I think what RFsystem said is right, the 1.5VDC is also the part of modulate diffrence signal.
