zainka
Full Member level 2
![Full Member level 2](/styles/images/ranks/elevel2.gif)
Hi
I am going to build a stepup power supply to make necessary power for my Ipod to be charged while driving. Thus I need a stepup converter to generate the 30V as used in firewire 6 pin contacts. IEEE1394 says each firewire ports can supply up to 45W so the step up converters I have found at maxim for example ar way to "flabby" to be able to give the ncesary power. My question is, does anyone know aboute a stepup converter that can prowide, say, 25-45 W at app. 5-15V in and 30V (or adj) out, or prehaps you know aboute any reff designs I can use??
Final, youst I thought i had... I guess the Ipod will regulate down the 30V given as input, so Prehaps I do not need the 30V given by firewire... Anyone knowing anything aboute Ipods internal voltages???, If this is less than voltage given by the car 12V outlet for cigarets many problems are solved already since there prehaps are no need for any stepup converters. Any ideas???
Thanks in advance
NOTE: I have an pretty old Ipod with only the 6 pin firewire port used for charging so some of the car chargers I have seen on marked wont fit....
Thanks in advance
