seyyah
Advanced Member level 2
intelligent power module ipm 15
This is my first use of an IPM. My purpose to use this igbt module is to simplfy the circuit but i'm a bit confused. I think it doesn't help to simplfy the circuit. Look at the attached schematic and help me about the connection please. The datasheet is here:
http://www.fujielectric.de/SEMI/Datenblatt/IGBT/6MBP50RA-120.pdf
My questions:
1- Can we directly interface this module to the mcu? If so all grounds will be connected to the logic ground.
2- If we must use optoisolator then can we use one supply for high side?
My questions:
