IPC-D-356A file in PROTEL 99SE ?
amjad
Full Member level 5
Full Member level 5
protel99se ipc
Is there any way to generate IPC-D-356A file in PROTEL 99SE? Can anyone answer pleease. Thanks.
You should have SP6 installed first to make sure that one of the bugs associated with testpoint generation has been fixed. Then use the CAM Manager (File>CAM Manager), and select 'Test Points'. The wizard will lead you through the file generation.
    amjad
Thank you so much House_Cat!.
