IP networking Tutorials
kmwing
Member level 4
Member level 4
uk
Hey Friends. I need IP Networking tutorials.please if anyone has please upload here.
Dear Kmwing.
You just go to isohunt.and download CCNA self study guide
Dear kmwing,
If do you want to learn IP Networking you need to learn basic cable,then OSI Layer after that read lecturer more about subnetting, Routing by download CCNA or take CCNA Course
An internet adress is a 32-bit number used to uniquely identify each host attached to an internet. We write addresses as a sequence of four eight-bit decimal numbers, separated by periods ("dot format").
TCP/IP implementations consider addresses as a two-part value: a network portion and a host portion.
There are three clases of internet networks defined for TCP/IP internets. The table below shows how the network portion of a dot format address of X.X.X.X takes up from one to three of the leading X's.
Class Network Portion Host Portion Numberof Hosts Sample IP Address
A 0-127 X.X.X 16,777,216 10.55.110.222
B 128-191.X X.X 65,536 128.123.90.2
C 192-255.X.X X 256 192.5.10.69
X is a value between 0 and 255.
Can you tell me how to choose an IP for a website as in what class of IP should be chosen is there any way to know which class of IP is better for a website
IP address for web site can be static or dynamic but in any case is from public IP address range. IP address is given from ISP pool of addresses. Usually static IP address is used, but if you are home user you can have web on your PC at home with dynamic IP address.
Reactions: kevinzo
    kevinzo
Refer CBT NUGGETS video. I did CCNA and it helped me lot.
Regards,
Isuranja
