Cindy_1998
Newbie
Hi, I want to confirm whether my schematic diagram is correct or not before I test my project. I cannot test the connection using the simulation because I use a new component, PZEM-004T. I have found an IoT project that used the same component, PZEM-004T. However, I also use the AC Light Dimmer component as I want to reduce the power consumption of the light bulb.
Here I attach my schematic diagram, the datasheet of PZEM-004T and AC Light Dimmer.
Datasheet of PZEM-004T
Datasheet of AC Light Dimmer
