jeff77789
Junior Member level 1
I have a Maxbotix MB1030 ultrasonic sensor, in which it gives out a "Tx" digital signal which is:
When the *BW is open or held low, the TX output delivers
asynchronous serial with an RS232 format, except voltages are 0-Vcc.
The output is an ASCII capital “R”, followed by three ASCII character
digits representing the range in inches up to a maximum of 255,
followed by a carriage return (ASCII 13). The baud rate is 9600, 8
bits, no parity, with one stop bit. Although the voltage of 0-Vcc is
outside the RS232 standard, most RS232 devices have sufficient
margin to read 0-Vcc serial data. If standard voltage level RS232 is
desired, invert, and connect an RS232 converter such as a MAX232.
When BW pin is held high the TX output sends a single pulse, suitable
for low noise chaining. (no serial data).
it mentions that the signal is inverted and you can use something such as a MAX232 to invert the signal...first of all i don't even know where to get one of those converters
if i wanted my arduino to read this signal, what can i do to invert the RS232 signal?
