Inverter design output/ fan speed
mord
Newbie level 6
Newbie level 6
I am into inverter design, I noticed that when a fan is connected, the speed is usually low. My oscillator is an SG3525 IC, I have seen several designs using the same IC with same configuration but when a fan is connected, it rotate very fast though still buzzing, I removed the filter cap from the other design but the speed still remains, what have they done differently, I think this has to do with the peak voltage(?). Please I need answer urgently. Thanks as you help
Are you talking about an inverter (AC output) or a converter (DC output)? In the latter case, does it use a storage inductor and filter capacitor, voltage feedback?
. yes, am refering to inverter (AC). There is no choke in the designs have been seeing. am still wandering about the difference
Feedback is usually included
Motors often buzz loudly when the AC supply has a waveform that is square-ish.
A sinewave causes only slight buzzing.
Yeah you right, but these inverters uses square wave oscillators, still they run fans fast only with slight buzzing
