StraightView
Member level 1
Hi everyone, A while ago I have made these inverter circuits in the pictures below but they didn't work no matter what I did so I stopped working on them, but now I'm I returned to try made them work and I faced the same problem like in the first time which means that when I measure the transformer output there is voltage shown in the meter and even high voltage sometimes but it can't even power up a load of 12v like a 12v relay, also when I connect the 12v relay to the transformer output the voltage goes to 0 whiteout powering the relay!!, I'm kind of sure that the switching is working fine, I can hear the noises made by the transformer that indicates that the switching is working if I'm not wrong about this information.
I have tested many, many ways without success to solve the problem, I'm sure that the transformers winding is correct and I have tested many transformers, I tested many NPN power transistors, many mosfets, I changed the resistors values, I tried anything comes to my mind.
I have thought that this problem is because of low current at the output so I tried to change the coils values many, many times, I tried with increasing the turns numbers of the secondary many times, decreasing the primary turns many times, I changed the wire diameter of both primary and secondary many times, I have made the secondary wire diameter larger for increasing current, all these tries and the problem insisted.
I thank and appreciate anyone help to solve this problem, thank you everyone.
