blue_electron
Banned
ads momentum pifa antenna
hi,
guys i'm tasked to design a low-profile small printed antenna that operate in 915MHz for GSM application. i have this book "planar antennas for wireless communications" by kin lu wong. there was a reference design on CPW-fed PIFA. what i have is ADS 2004a Momentum. I have been really struggling with the proper application of PORTS and truncated GROUNDS noting the limitation of ADS to infinite groundplane and substrate...
below is the image of my layout in ADS with the following dimensions and specs.
the middle port is the CPW-fed port single, 50 ohm port. the other two ports at the sides are GROund reference port to 1.
http://usera.imagecave.com/krazooom/substratelayerdef.JPG
http://usera.imagecave.com/krazooom/metallizationlayer.bmp.jpg
according to the book, the resonant frequency should be about 2045MHz with a 20%BW as shown by the response , however it is different from the result above
please help me verify such design if you have ANSOFT HFSS to layout such structure and compare the response..
i would greatly appreciate your help on this!
thanks!
hi,
thanks!
