circuitking
Full Member level 5
Hello, I gave the data generated by rand_bit_stream (from ahdlLib library) to an inverter but I don't get inversion of the data at the output of the inverter. The rand_bit_stream data output is good, there is no problem with that, the problem is only with the inverted data. There is also no problem with my inverter because I gave other data and it inverted properly. Can anyone try this and tell me what is wrong with the rand_bit_stream.
