well inverse laplace can be done by two ways by using the formula as follows
or if the h(s) given is of the form Nr/Dr
then go for partial fraction , if ROC is not sepceified then u can take the system as causal and find the inverse LT by using basic Laplace transform formule for exp(at) or sin(at) or cos(at) so on
or u can use this if u r confortable
x(t)=(1/(2Πj)*(∫exp(st)X(s)ds)
where the limits of ∫ is σ+j∞ is Upper limit and σ-j∞ is lower limit
usually all the ILTs can b doen by the first method :smile:
---------- Post added at 10:58 ---------- Previous post was at 10:56 ----------
hey perado what are lambda and mu ? r they some constsnts?
