rizwanbashir
Newbie level 2
I am designing a buck boost converter whose input ranges from 2.5V to 4.0V and the output is a fixed 3.2V.
Now this converter will behave as a buck converter in the range from 3.2V to 4.0V and will act as a boost converter in the range from 2.5V to 3.2V.
My question is about intrinsic safety, as the instrument in which this has to be used will be placed in a hazardous and explosive environment, will there be any time in which the output voltage might exceed a certain limit that it can cause an explosion?? Or the voltage at any pin exceeds a certain limit to ignite a spark?
If yes, what can I do as a remedy for this?
Thanks
Thanks
