Interview Questions Related to SET-UP and HOLD Time
spartanthewarrior
Full Member level 2
Full Member level 2
setup and hold time equation
Hi All,
Can any body tell me
What are the possible questions on SET-UP and HOLD time for interview.
hold time equation
Question
write down the famous/basic setup & hold equations.
Answer
setup equation
Tclk > Tclktoq + Tlogic + Tsetup + Tskew + Tjitter
hold equation
Tclktoq + Tlogic - Tskew > Thold
key things to note from above equations
a) once the silicon comes back , if u have setup time problem , u can
increase the clock period (Tclk) to fix it , whereas if u have hold
time problem , its a more serious problem and u will need a new
metal fix tapeout .
b) PLL jitter (Tjitter ) is not used in holdtime equation , since hold
time violation is based on same clock edge . (whereas setup time
vioation depends on 2 consecutive clock edges)
c) above equaitons have clock skew in pessimistic directions . U can play
around with clock skews to get extra margin by skewing them in
favourable direction to decrease violation .
d)from above equations , u can easily answer questions like
"how do u fix setup violations ?" ( faster flop , flop with less setup time , smaller logic between flops , etc ...)
"how do u fix hold violations ?" ( use mindelay flop i.e flop with bigger clock to q , etc ... )
setup and hold time questions
also you should read the PT report!
