Interview questions for digital circuit
s3034585
Full Member level 4
Full Member level 4
hi can any give some interview questions for digital circuit design
thanks in advance
if your are a new guy and apply for IC DESIGN(not Dianostic):
Rising Time Falling Time Setup Time
FiFo /Dualport RAM /Asyn CKT
State Machine
MPU concept
if you apply for special product (ex: DSC)
then you need understand Algorithm/DSP.....)
If you want to do some ic design of digital circuit, you should see some texts about VLSI design, for example cmos design.
1. What is setup/hold time and metastability?
2. How to interconnect two synchronous digital design with different clock domains?
or How to connect asynchronous external signal to synchronous design?
3. What is DFT? (sometimes say Discrete Fourier Transformation :)).
4. Whal is logic race?
1. design an Frequency divide by 2 circuit using T-FF
2. design an Frequency divide by 3 circuit using T-FF, JK_FF, RS-FF
3. Design an edge detection circute
4. design a summing amplefier
Here is the one I recently heard:
a 2-bit full adder has inputs a, b, ci, and outputs s and co. Use this building block to build a circuit to do the following task:
Count how many 1s are there in a 7-bit word, b6b5...b0.
1.design a digital circuit that can count the number of 1s in the n-bit data stream
2.design a and,or,not gate using an arbitrary gate like y=a+b'
---------- Post added at 14:33 ---------- Previous post was at 14:31 ----------
what is the answer for "Count how many 1s are there in a 7-bit word, b6b5...b0. " ??
I stucked to this question at my interview once.stil looking for the optimized solution !!
