Interrupt programming help
Rohith_elec
Full Member level 4
Full Member level 4
What is the difference between software interupt and hardware interrupt ?
is the software interrupt initiated when a condition inside a code is satisfied ?
can anyone provide an example ?
thank you
Rohith
An example of software interrupt:
When the Timer 1 of PIC18F4620 gets overflowed, it automatically sets the INTCONbits.TMR0IF to 1.
Hardware interrupt is more like , pressing buttons on demo boards ( from an external stimuli)
can the software interrupt can be of any number ?
What do you mean by any number? You have high, low priority on the interrupts. You can also select high-to-low or the other way round !
ok , i was asking that 5 different pushbutton and 5 different actions on each like , controlling an LED , controlling a motor , pwm on led and so forth
Hmm sure you can ! Controlling a motor, PWM would require a lot of coding but you can certainly do that!
Can the below code can be used for PWM ?
void pwm(int c)
output_high(PIN_B0);
delay_us(30);
output_low(PIN_B0);
delay_us(c);
by varying the delay , can we adjust the duty cycle ?
If its a function then you need a "return;" at the end of your pwm function!
Yup, I see no reason that will not work.
for an application like LED or motor , do i need to set the frequency (PWM frequency)?
