[PIC] Interrupt based pulse counting for PIC 32
abhijith94
Newbie level 2
Newbie level 2
hi,
i am trying to write a pulse counter using PIC32, and my code is not working can someone please help me on this.
Code C++ - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <plib.h>
#include <string.h>
#define BAUDRATE 115200
#define GetSystemClock()            (80000000ul)
#define GetPeripheralClock()        (GetSystemClock()/(1 << OSCCONbits.PBDIV))
#define GetInstructionClock()       (GetSystemClock())
int count=0;
void __ISR(_EXTERNAL_0_VECTOR, IPL2SOFT) Ext0ISR(void) { // step 1: the ISR
    count = count + 1;
IFS0CLR = 1 << 3;
int main(int argc, char** argv) {
    //int count;
    char ct[10];
    UARTConfigure(UART2, UART_ENABLE_PINS_TX_RX_ONLY);
    UARTSetFifoMode(UART2, UART_INTERRUPT_ON_TX_NOT_FULL | UART_INTERRUPT_ON_RX_NOT_EMPTY);
    UARTSetLineControl(UART2, UART_DATA_SIZE_8_BITS | UART_PARITY_NONE | UART_STOP_BITS_1);
    UARTSetDataRate(UART2, GetPeripheralClock(), 115200);
    UARTEnable(UART2, UART_ENABLE_FLAGS(UART_PERIPHERAL | UART_RX | UART_TX));
    INTDisableInterrupts(); // step 2: disable interrupts at the CPU
INTCONCLR = 0x1; // step 3: INT0 triggers on falling edge
IPC0CLR = 0x1F << 24; // step 4: clear the 5 pri and subpri bits
IPC0 |= 9 << 24; // step 4: set priority to 2, subpriority to 1
IFS0bits.INT0IF = 0; // step 5: clear the int flag, or IFS0CLR=1<<3
IEC0SET = 1 << 3; // step 6: enable INT0 by setting IEC0<3>
INTEnableSystemMultiVectoredInt();
while(1)
    itoa(count,ct,10);
    putsUART2("count is:");
    putsUART2(ct);
    putsUART2("\n");
    return (EXIT_SUCCESS);
Re: interrupt based pulse counting for PIC 32
First step, define "my code is not working".
I assume the PIC has a hardware counter, if so: why don't you use it?
Klaus
I am able to build it but it's going to rest: jal_startup when I execute it. No I can't use hardware counter as I am trying to develop a program that counts the external pulses
Could you clarify that enigma ?
By the way: What is working so far ?
What is not working as expected ?
Please confirm: "you kow that a hardware counter can be used, but you don´t want to use it".
What is the idea behind this?
What benefit do you see in using a software counter instead of a hardware counter?
Klaus
