interprocess communication
banh
Advanced Member level 1
for very small & limited system (esp. small RAM), which methods are good for interprocess communication?:
- using shared variables with mutex.
- using mailboxes - similary to a queue with many producers and consumers.
..any other?
THis depends what and how you are going to pass data from one proess to another .
Queues are good for passing large sized data in form of messages (mailbox used if you have one message to be read before next will be put into queue) .Mutex is usefull when protecting access to the resources (if only one user could access to resource at a time) . Semaphores are usefull when dealing with resource allocation if you have certain amount of resources (let say buffers ) .
Share Memory would be a good idea if sync. is not an important issue.If sync. has to be consider i would prefer 2-way share memory access.
If there are a lot of client accessing for competition
i would suggest share memory with critical session or mutex or signal.
Regards
Shared memory is good idea
but if process is critical then use mutex
if sync is required then use semaphore
but it is very important to study time graph of your system at run time
this would give you a inside picture of various bottle necks if at all so you can decide and chose diffrent IPC for diffrent process
Added after 55 seconds:
