Internet Inside Chip - IIM7010A
asena
Member level 4
Member level 4
Portugal
nm7010a pic18f452
hello!
is anyone using this module from WIZnet ?
I am looking for some code on interfacing it to a PIC. Assembler or C.
Thanks very much
asena
Dear Asena,
I'm just trying to use the IIM7010A modul in TCP Server mode with PIC18F452.
I'm at the begining, but it partly works. It means, that I can ping the modul from PC, but I have not been able to connect to the modul by client.
You can find sample codes on:
**broken link removed**.
I know that these are for ATMEL controller, but I modify them for PIC C compiler.
If you need, the code yust mail me, than I send it to you.
Best regards,
Zotya
setting IIM7010A IP
I really need the software for assigning IP to the IIM7010A module.
If anyone could please upload it or give a link to the exact file.
Thanks a lot!
Dear Zkochovski,
I've managed to implemet the ATMEL sample code for PIC javascript:emoticon(':)').
The WIZ-C compiler was used to build the project.
I used I2C communicate with the modul. It is quite slow but it works.
See the attached project.
If you have any question I'll try to help.
Regards,
Zotya
Hi
I am now using NM7010A to connect to PIC18F452, too.
I have some question. Is the PIC C Compiler work??? Or do I need the WIZ Compiler???
