pateldivyesh68@gmail.com
Member level 3
design a microcontroller 8051 based display control system to display numbers..from 0 to 9999d.four segment display modules are common cathode type.draw the circuit diagram with multiplexer to indicate how single port can be used to connect four modules.use port p1 to connect 7 segment display.only draw the flow chart for logical program implementation.....plz give me some solution to this problem....
