BALKRISHNA TULSYAN
Junior Member level 3
Dear all,
Can anyone explain how MOSFET switching should takes place in two stage synchronous buck converter.
Normally in synchronous buck converter High side and Low side MOSFET should be switched On alternately but what should be the switching sequence in case of interleave design.
Whether both High side MOSFET should be switched ON at the same time and Low side MOSFET should be switched off at the same time like we normally do with single stage synchronous buck converter or my i misunderstood the concept.
Please correct me if i am wrong.
