Do you have to use that exact model of accelerometer?sorenriis said:Also - actually it's not just one accelerometer I would like to interface with.
Actually I need 3 (x-,y-,z-axis), but how is that done?
Just a little point: "2M" means "two millis" for orcad, while what you would have to have written, was "2Meg"sorenriis said:The reason was that somehow OrCAD didn't understand "2M", but was ok with "2000k".
Hehe... Thanks for letting me knowhalls said:Just a little point: "2M" means "two millis" for orcad, while what you would have to have written, was "2Meg"
Thanks. I will stick with the LTC2487 then - unless someone else comes up with something betterhalls said:...i guess that sigma-delta ADC would be a good option...
Could you tell me what graph you are looking at?halls said:On normal performance i think you could reach even 30kHz sampling frequency. Just take a look at the graphs shown on the datasheet
Output Data Rate
When using its internal oscillator, the LTC2487 produces
up to 15 samples per second (sps) with a notch frequency of
60Hz. The actual output data rate depends upon the length
of the sleep and data output cycles which are controlled
by the user and can be made insignificantly short. When
operating with an external conversion clock (FO connected
to an external oscillator), the LTC2487 output data rate
can be increased. The duration of the conversion cycle is
41036/fEOSC. If fEOSC = 307.2kHz, the converter behaves
as if the internal oscillator is used.
An increase in fEOSC over the nominal 307.2kHz will translate
into a proportional increase in the maximum output
data rate (up to a maximum of 100sps).....
