samic45mit1
Member level 3
Hello,
I am interfacing W25M512 IC with the microcontroller and devise ID(By sending 0X90 i get 0XEF) is read successfully. But when I try to write and read data on rom then I always get 0XFF.
I am using a soft SPI lib for communication and I think it is working fine. My code is given below. So please help me to solve the problem.
int main(void)
unsigned char data =0XAA,rom_data;
unsigned char address=100;
FlashWriteData(address,&data,1);
while(1)
FlashReadData(address,&rom_data,1);
ms(25);
/***************************Read data form memory*****************************/
unsigned char tyt; //Global variable to monitor data on debugger
unsigned char FlashReadData (unsigned long address, unsigned char *data,unsigned long size)
unsigned char command[5];
while(1){ //Check the status of the rom
status= read_status();
if(status!=1)break;
WriteEnable(); us(550);
CS_L;
us(550);
/*Initialize peripheral for SPI */
/*This section reads back data. The first character is the read command */
command[0] = 0x03;
command[1] = ((unsigned char)(address >> 16) & 0XFF);
command[2] = ((unsigned char)(address >> 8) & 0XFF);
command[3] = ((unsigned char)(address >> 0) & 0XFF);
soft_spi_data_write(command,1);
soft_spi_data_write(command+1,1);
soft_spi_data_write(command+2,1);
soft_spi_data_write(command+3,1);
tyt=soft_spi_data_read();
*data=tyt;
us(550);
CS_H;
return(0);
/***************************Write data on memory*******************************/
Input--Address, *data, size--no of byte to write
void FlashWriteData (unsigned long address, unsigned char const *data,int size)
unsigned char command[9];
unsigned char data_var;
data_var=*data;
WriteEnable(); us(550); //Send 0X06 command for write enable
WriteUnprotect(); us(550); //Allow memory to be modified
while(1){ //read status register 1 and wait till any write operation is finished
if(status!=1)break;
CS_L;
us(550);
command[0] = 0x02; //Write command
command[1] = ((unsigned char)(address >> 16) & 0XFF); //Send address in three byte address mode
soft_spi_data_write(command,4); //Send command 0X02 and then address
soft_spi_data_write(&data_var,1); //Send data on eeprom
us(550);
CS_H;
// WriteProtect();
void WriteProtect (void)
unsigned char command[2];
CS_L;
/* This section writes data. The first character is the write command */
command[0] = 0x01; //Write on status regidter
command[1] = 0x80;
soft_spi_data_write(command, 2);
//commented
/* close peripheral for SPI */
CS_H;
/***********************Disable globel protect*************************************************/
void WriteUnprotect (void)
/* send write enable command */
GlobalBlockProtectionUnlock();
ms(1);
CS_L;
us(500);
command[0] = 0x01;
command[1] = 0x00;
soft_spi_data_write(command,2);
// GlobalBlockProtectionUnlock();
us(500);
CS_H;
void GlobalBlockProtectionUnlock (void)
unsigned char command = 0x98;
/* Initialize peripheral for SPI */
CS_L;
us(500);
soft_spi_data_write(&command,1);
us(500);
CS_H;
return;
/***********Read the status register 1 of memory**************************/
unsigned char FlashReadStatus (void)
unsigned char command,response;
CS_L;
ms(1);
command = 0x05;
soft_spi_data_write(&command, 1);
us(10);
response=soft_spi_data_read();
ms(1);
CS_H;
return(response);
/****************Reading data form SPI************************/
unsigned char soft_spi_data_read(void)
unsigned char i=0;
_Bool pin;
data_sp=0;
for(i=0; i<8; i++)
clk_h;
us(100);
pin=read_spi;
if(pin==true)
data_sp=(data_sp | (0x80>>i));
clk_l;
us(100);
return(data_sp);
/**************************For writing data or command on SPI**********************************/
void soft_spi_data_write(unsigned char *data,int no){
unsigned char i, maskdata = 0X80; //0x80;
int loop;
unsigned char d;
d=*data;
for(loop=0;loop<no;loop++)
for(i= 0;i<8;i++)
if(*(data+loop) & maskdata)
d_out_h;
else
d_out_l;
maskdata >>= 1;
clk_h;
us(100)
clk_l;
us(100);
d_out_l;
clk_h;
return;
