interfacing PS-2 keyboard
thanks
thanks dear ebenni
but if you have asm code please send it for me
thanks
yours
S 8O KRAT
have some questions about keyb.. if someone...
I haven't found any information about this questions, and are important for me:
1- if keyb is retransmiting last byte (because host sent a Resend) and host inhibits the bus in the middle of transmition
, after processing the new command... keyb should resend the last byte without waiting for Resend command or should wait
for a Resend comand from host?. IE:
keyb host
Z ----->
A ----->
<---- Resend
A --X (host inhibit bus) why? I think Host can do it.
<---- sends another comand -not Resend-
should keyb try to send again key "A"? next key in buffer? wait another Resend commando from host? ...?
how sending "A" keyb was interrupted, the LastKey sent will be "Z"?
2- This case:
keyb host
A ----->
<---- command (not resend)
ACK ----->
<---- Resend
what should resend the keyboard? "A" key, or only "ACK", or the complete command packet?
3- how many Resends must send the keyboard before sending a 0xFC? (I think 1 resend and if the second byte from host
is still wrong, then keyb sends oxFC)
what does keyb after transmiting a 0xFC error code? stands waiting commands from host? stops keys scanning? ...?
if u can help, yuhuuuuu, if can't.. : ( but.. ok! thanks :)
mmmmmmmmh
thanks but... I read it before... really I have read hundreds of links, but nothing.. and now, I ever find out the same webs when search in google xDDDd I think I have read all -or almost all- xDDD
thanks
hi all friends
i'm finsh my asm code to interface AT pc keyboard and at89c2051 and the output will be display to 2*16 lcd
if any one want it send to me pm
thanks
yours
S 8O KRAT
Keyboard
Hello,
anybody an idea where i can get a listing contain key combinations for generating values from 0x0 to 0xFF with a ordinary keyboard (like ctrl A according 0x1)
Thanks a lot
Robby
keyb codes
do you want scan codes or ascii codes?
You can find all codes searching them with google. Or try here:
bye :D
