jegues
Member level 3
The PIC being used is: PIC16F877A
LCD beind used is:
NHD‐0216KZ‐FSW‐GBW
The objective is to get the LCD to display the following message,
"Bananas $0.49/lb" - for 5 seconds, followed by,
"WOW!" - which is centered on the display and blinking at a rate of once per second for 3 seconds (i.e. 500ms on 500ms off).
I'm having trouble finding information on the correct procedure to use the LCD, and a large portion of the code used in my program has been provided by our instructor.
I have a feeling that before I attempt to, writeString("Hello World!"), to the LCD I must first set the display line and place the cursor accordingly which I don't know how to do. We have been given an incomplete function called setDisplayLine(), but I'm not entirely sure in what sense it is incomplete, nor what the codes being passed to the command function represent.
Then again, I'm not even sure if that is the correct procedure to follow.
Does anyone know?
I've been looking for a data sheet, but all I've been able to find is pinouts which I already have.
See below for my code. (I appologize as the indentation is ruined when I paste it into the forum)
Thanks for the help!
And the code for portInit(),
LCD beind used is:
NHD‐0216KZ‐FSW‐GBW
Does anyone know?
#include <htc.h>
#include <string.h>
#include "ProcessorConfiguration.h"
#include "FunctionPrototypes.h"
#include "Definitions.h"
void main(void){
portInit();
LCDInit();
writeString("Hello World!");
static void interrupt isr(void){
//May be moved to its own .c file later
void LCDInit(void){
E = 0;
delay(15); //Wait >15 msec after power is applied
initCommand(0x30); //command 0x30 = Wake up
delay(5); //must wait 5ms, busy flag not available
initCommand(0x30); //command 0x30 = Wake up #2
delay(160); //must wait 160us, busy flag not available
initCommand(0x30); //command 0x30 = Wake up #3
command(0x38); //Function set: 8-bit/2-line
command(0x10); //Cursor shift mode, S/C to the Left
command(0x0C); //1DCB: Display ON; Cursor OFF; Blink OFF
command(0x06); //Entry mode: Inc cursor and display shift off
clearDisplay();
returnHome();
void initCommand(char theCommand){ //Cannot Utilize BF
LCDCOMMAND = theCommand; //put command on PORTD
RS = RS_COMMAND; // Select Command Register
RWn = WRITE; // Write Mode
E = 1;
E = 0; //Clock enable: falling edge
void command(char theCommand) {
waitForNotBusy();
E = 1;
void clearDisplay(void) {
waitForNotBusy();
command(0x01); //Clear Display
void returnHome(void) {
waitForNotBusy();
command(0x02); //Return Home
void waitForNotBusy(void) {
unsigned char BF;
RWn = READ; // Read Mode
BF = 0b10000000;
TRISD = 0b11111111;
delay(1); // Wait at least 80 μs before reading BF
while(BF==0b10000000){
E = 1;
BF = LCDDATA & 0b10000000;
TRISD = 0b00000000;
void delay(unsigned char loops) {
unsigned char i;
loops += 69;
for(i=0; i<loops;i++){}
//End of block pasted from LCDInitialization.c
void setDisplayLine(unsigned char line, unsigned char position) { //This function is incomplete.
switch(line) {
case 1:command(0b01000000);
break;
case 2:command(0b11000000);
break;
void writeChar(char theData) {
waitForNotBusy();
LCDDATA = theData; //put data on PORTD
RS = RS_DATA; // Select Data Register
E = 1; //enable pulse width >= 300ns
void writeString(char *theString) {
unsigned char i;
for(i = 0; i < strlen(theString); i++) {
waitForNotBusy();
LCDDATA = theString[i]; // Put data on PORTD
E = 1; // Enable pulse width >= 300ns
E = 0; // Clock enable: falling edge
#include <htc.h>
void portInit(void){
//Configure for Digital IO
PCFG3 = 0;
PCFG2 = 1;
PCFG1 = 1;
TRISE0 = 0;
TRISE1 = 0;
TRISE2 = 0;
TRISD = 0b00000000; //Configure PORTD for output
INTCON = 0; //Disable interrupts.
