Interfacing OLED with ESP32 WROOM32
pacman22
Junior Member level 1
I want to connect two OLED display modules to ESP32. I want these OLEDs to display the same image at the same time. Will daisy chaining these two displays work? These displays will be communicating over 4-wire SPI.​
Display: https://www.waveshare.com/1.5inch-rgb-oled-module.htm
ESP32WROOM32: https://www.espressif.com/sites/def...2-wroom-32e_esp32-wroom-32ue_datasheet_en.pdf
Instead of daisy chaining them, I´d rather parallel connect them.
I just recognized the OLEDs don´t even have a data output ... then how is your idea to daisy chaining them at all?
For independent access they offer the CS signal .. on the same SPI bus.
Klaus
Klaus
Share all SPI signals among both the displays including chip select. Is this what you mean?
Will both displays be observable in the same visual field ?
Asking because the controllers in the OLED display have asych processes,
and you could see artifacts possibly in both displays that would be observable from
same point of view.
Regards, Dana.
