hello,
wich kind of RTC
DS1302 SPi
DS1307 I2C
other ?
LCD 4bits 2x16 , 4x20 ?
direct or trough I2C ?
so with 2 wires SDA,SCL you can drive LCD,EEPROM,RTC
Thanks sir for your reply
we are using DS1307 through i2c
using LCD 4bits 2x16
Which uC are you using? Does it have internal eeprom or do you want to use external eeprom. What is the Clock frequency? Which Compiler are you using? mikroC PRO Compiler?
