Interfacing micro 89c51 to the network via ethernet
TheSniper
Member level 3
Member level 3
Interface to the network
i need to connect the micro 89c51 into the
lan network via ethernnet
Anny sugestions ???????
Re: Interface to the network
Hi. Download the book TCP/IP lean.
Or, search within this forum with TCP/IP. You will find a lot of information.
    TheSniper
this is 8052 for TCP/IP project **broken link removed**
    TheSniper
i took a look in the 8052 website
but i do not want to interface with an isa card i want to make it just like the serial or the parallel port
meanning i want to connect the micro to the net via rj45.
TheSniper(+)
thanks feiutm9898 for your help
i have found this project (web-51)
it is based on a 8052 MCU
if you have got time pleas check it out and tell me
you opinion i will appreciate it .
thanks
TheSniper (+)
hi sniper if u have any information about power line communication plz send to me about it such any web u know thx
