john120
Banned
hELLO every body,I have a long program which is demonstrated here below, it not being executed because the pic memory has been become full so I want to use the external EERPOM can you plz help me to handle the issue I have 24lc256
Thanks;see the codes below:the if...else...if teste and evaluate the value of frequency read on the T1CKI pin;or help me about the array whic hreduces those if....else....if statements I think those arrays can also help:
#include <16F877A.h>
#DEVICE ADC=10
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include "lcd.c"
#define ka PIN_C3
#use fast_io(c)
#use fast_io(b)
#use fast_io(a)
void tempdisplay();
void kagaba();
void messagedisplay();
void final();
float voltsf,volts;
float period;
double jean;
float value;
double value1;
unsigned int adc_value;
void final(void)
if((value>=1234900) && (value1<=1235900))
jean=7.2;
else if((value>=1234100) && (value1<=1234800))
jean=7.3;
else if((value>=1234000) && (value1<=1231900))
jean=7.4;
else if((value>=1231500) && (value1<=1231800))
jean=7.5;
else if((value>=1230090) && (value1<=1230300))
jean=7.6;
else if((value>=1228900) && (value1<=1230100))
jean=7.7;
else if((value>=122600) && (value1<=1228000))
jean=7.8;
else if((value>=1226200) && (value1<=1226400))
jean=7.9;
else if((value>=1224800) && (value1<=1226120))
jean=8.0;
else if((value>=1223001) && (value1<=1224500))
jean=8.1;
else if((value>=1222999) && (value1<=1223000))
jean=8.2;
else if((value>=1220999) && (value1<=1223000))
jean=8.3;
else if((value>=1220001) && (value1<=1221000))
jean=8.4;
else if((value>=1219999) && (value1<=1220000))
jean=8.5;
else if((value>=1217995) && (value1<=1219999))
jean=8.6;
else if((value>=1218000) && (value1<=1219996))
jean=8.7;
else if((value>=1217939) && (value1<=1217999))
jean=8.9;
else if((value>=1217000) && (value1<=1217938))
jean=9.0;
else if((value>=1216000) && (value1<=1216999))
jean=9.1;
else if((value>=1215130) && (value1<=1215999))
jean=9.2;
else if((value>=1215000) && (value1<=1215129))
jean=9.3;
else if((value>=1212000) && (value1<=1214999))
jean=9.4;
else if((value>=1210000) && (value1<=1212000))
jean=9.5;
else if((value>=1209900) && (value1<=1209999))
jean=9.6;
else if((value>=1209500) && (value1<=1209899))
jean=9.7;
else if((value>=1209800) && (value1<=1209499))
jean=9.8;
else if((value>=1208500) && (value1<=1209799))
jean=9.9;
else if((value>=1207000) && (value1<=1208499))
jean=10;
else if((value>=1205000) && (value1<=1206999))
jean=10.1;
else if((value>=1202500) && (value1<=1204999))
jean=10.2;
else if((value>=1201500) && (value1<=1202499))
jean=10.3;
else if((value>=1201000) && (value1<=1201499))
jean=10.4;
else if((value>=1200000) && (value1<=1200999))
jean=10.5;
else if((value>=1199500) && (value1<=1199999))
jean=10.6;
else if((value>=1199000) && (value1<=1199499))
jean=10.7;
else if((value>=1198500) && (value1<=1198999))
jean=10.8;
else if((value>=1197000) && (value1<=1198000))
jean=10.9;
else if((value>=1196900) && (value1<=1196899))
jean=10.9;
else if((value>=1196000) && (value1<=1196899))
jean=11.0;
else if((value>=1195500) && (value1<=1195999))
jean=11.1;
else if((value>=1195000) && (value1<=1195499))
jean=11.2;
else if((value>=1194500) && (value1<=1194999))
jean=11.3;
else if((value>=1194000) && (value1<=1194499))
jean=11.4;
else if((value>=1193500) && (value1<=1193999))
jean=11.5;
else if((value>=1193000) && (value1<=1193499))
jean=11.6;
else if((value>=1190000) && (value1<=1192999))
jean=11.7;
else if((value>=1188500) && (value1<=1189999))
jean=11.8;
else if((value>=1187000) && (value1<=1188000))
jean=11.9;
else if((value>=1184100) && (value1<=1186999))
jean=12.0;
else if((value>=1183240) && (value1<=1184099))
jean=12.1;
else if((value>=1182230) && (value1<=1183239))
jean=12.2;
else if((value>=1181200) && (value1<=1182229))
jean=12.3;
else if((value>=1181000) && (value1<=1181199))
jean=12.4;
else if((value>=1180000) && (value1<=1180999))
jean=12.5;
else if((value>=1179000) && (value1<=1179999))
jean=12.6;
else if((value>=1173850) && (value1<=1174949))
jean=12.7;
else if((value>=1173650) && (value1<=1173849))
jean=12.8;
else if((value>=1173500) && (value1<=1173649))
jean=12.9;
else if((value>=1172500) && (value1<=1173499))
jean=13.0;
else if((value>=1171500) && (value1<=1172499))
jean=13.1;
else if((value>=1170000) && (value1<=1171499))
jean=13.2;
else if((value>=1168500) && (value1<=1169999))
jean=13.3;
else if((value>=1167500) && (value1<=1168499))
jean=13.4;
else if((value>=1166000) && (value1<=1167499))
jean=13.5;
else if((value>=1164500) && (value1<=1165999))
jean=13.6;
else if((value>=1163000) && (value1<=1164499))
jean=13.7;
else if((value>=1159999) && (value1<=1162999))
jean=13.8;
else if((value>=1158500) && (value1<=1159997))
jean=13.9;
else if((value>=1157500) && (value1<=1158499))
jean=13.9;
else if((value>=1156500) && (value1<=1157499))
jean=14.0;
else if((value>=1155000) && (value1<=1156499))
jean=14.1;
else if((value>=1153500) && (value1<=1154999))
jean=14.2;
else if((value>=1151500) && (value1<=1152500))
jean=14.3;
else if((value>=1150500) && (value1<=1151499))
jean=14.4;
else if((value>=1149880) && (value1<=1150499))
jean=14.5;
else if((value>=1144000) && (value1<=1149870))
jean=14.6;
else if((value>=1143000) && (value1<=1143999))
jean=14.7;
else if((value>=1141800) && (value1<=1142999))
jean=14.8;
else if((value>=1141500) && (value1<=1141799))
jean=14.9;
else if((value>=1142600) && (value1<=1143499))
jean=15.0;
else if((value>=1141500) && (value1<=1142599))
jean=15.1;
else if((value>=1140400) && (value1<=1141499))
jean=15.2;
else if((value>=1139600) && (value1<=1140399))
jean=15.3;
else if((value>=1138560) && (value1<=1139599))
jean=15.4;
else if((value>=1137500) && (value1<=1138559))
jean=15.5;
else if((value>=1136500) && (value1<=1137499))
jean=15.6;
else if((value>=1135500) && (value1<=1136499))
jean=15.7;
else if((value>=1134500) && (value1<=1135499))
jean=15.8;
else if((value>=1133500) && (value1<=1134499))
jean=15.9;
else if((value>=1129999) && (value1<=1133499))
jean=16.0;
else if((value>=1128500) && (value1<=1129998))
jean=16.1;
else if((value>=1127500) && (value1<=1128499))
jean=16.2;
else if((value>=1127500) && (value1<=1127499))
jean=16.3;
else if((value>=1123500) && (value1<=1124998))
jean=16.4;
if((value>=1122500) && (value1<=1123499))
jean=16.5;
else if((value>=1121500) && (value1<=1122499))
jean=16.6;
else if((value>=1119950) && (value1<=1121499))
jean=16.7;
else if((value>=1118500) && (value1<=1119949))
jean=16.8;
else if((value>=1117500) && (value1<=1118499))
jean=16.9;
else if((value>=1116500) && (value1<=1117499))
jean=17.0;
else if((value>=1115000) && (value1<=1116499))
jean=17.1;
else if((value>=1113500) && (value1<=1114999))
jean=17.2;
else if((value>=1112000) && (value1<=1113499))
jean=17.3;
else if((value>=1110500) && (value1<=1111999))
jean=17.4;
if((value>=1108000) && (value1<=1109000))
jean=17.5;
else if((value>=1106500) && (value1<=1107999))
jean=17.6;
else if((value>=1105200) && (value1<=1106499))
jean=17.7;
else if((value>=1103500) && (value1<=1105199))
jean=17.8;
else if((value>=1102500) && (value1<=1103499))
jean=17.9;
else if((value>=1101000) && (value1<=1102499))
jean=18.0;
if((value>=1099799) && (value1<=1100999))
jean=18.1;
else if((value>=1098500) && (value1<=1099798))
jean=18.2;
/*else if((value>=1097500) && (value1<=1098499))
jean=18.3;
else if((value>=1096400) && (value1<=1097499))
jean=18.4;
else if((value>=1095200) && (value1<=1096399))
jean=18.5;
else if((value>=1094000) && (value1<=1095199))
jean=18.6;
else if((value>=1092500) && (value1<=1093999))
jean=18.7;
else if((value>=1091500) && (value1<=1092499))
jean=18.8;
if((value>=1090000) && (value1<=1091499))
jean=18.9;
else if((value>=1088500) && (value1<=1089999))
jean=19.0;
else if((value>=1087500) && (value1<=1088499))
jean=19.1;
else if((value>=1086200) && (value1<=1087499))
jean=19.2;
if((value>=1085000) && (value1<=1086199))
jean=19.2;
else if((value>=1082000) && (value1<=1084999))
jean=19.3;
else if((value>=1080000) && (value1<=1081999))
jean=19.4;
else if((value>=1078500) && (value1<=1079999))
jean=19.5;
else if((value>=1077500) && (value1<=1078499))
jean=19.6;
else if((value>=1076500) && (value1<=1077499))
jean=19.7;
else if((value>=1075900) && (value1<=1076499))
jean=19.8;
else if((value>=1075860) && (value1<=1075899))
jean=19.9;
else if((value>=1075830) && (value1<=1075859))
jean=20.0;
else if((value>=1074820) && (value1<=1075829))
jean=20.1;
else if((value>=1073500) && (value1<=1074819))
jean=20.2;
else if((value>=1072500) && (value1<=1073499))
jean=20.3;
else if((value>=1071200) && (value1<=1072499))
jean=20.4;
else if((value>=1070000) && (value1<=1071199))
jean=20.5;
else if((value>=1068500) && (value1<=1069999))
jean=20.6;
else if((value>=1067200) && (value1<=1068499))
jean=20.7;
else if((value>=1066100) && (value1<=1067199))
jean=20.8;
else if((value>=1065000) && (value1<=1066099))
jean=20.9;
else if((value>=1063200) && (value1<=1064999))
jean=21.0;
else if((value>=1062400) && (value1<=1063199))
jean=21.1;
else if((value>=1061300) && (value1<=1062399))
jean=21.2;
else if((value>=1061000) && (value1<=1061299))
jean=21.3;
else if((value>=1060000) && (value1<=1060999))
jean=21.4;
else if((value>=1058000) && (value1<=1059999))
jean=21.5;
else if((value>=1056000) && (value1<=1057999))
jean=21.6;
else if((value>=1055000) && (value1<=1055999))
jean=21.7;
else if((value>=1054000) && (value1<=1054999))
jean=21.8;
else if((value>=1053000) && (value1<=1053999))
jean=21.9;
else if((value>=1051950) && (value1<=1052999))
jean=22.0;
else if((value>=1051500) && (value1<=1051949))
jean=22.1;
if((value>=1050000) && (value1<=1051499))
jean=22.2;
//if((value1>=1048500) && (value1<=1049999))
//jean=22.3;
else if((value1>=1047000) && (value1<=1048499))
jean=22.4;
else if((value1>=1045500) && (value1<=1046999))
jean=22.5;
else if((value1>=1044000) && (value1<=1045499))
jean=22.6;
else if((value1>=1042500) && (value1<=1043999))
jean=22.7;
else if((value1>=1041200) && (value1<=1042499))
jean=22.8;
else if((value1>=1040000) && (value1<=1041199))
jean=22.9;
else if((value1>=1038500) && (value1<=1039999))
jean=23.0;
else if((value1>=1037000) && (value1<=1038499))
jean=23.1;
else if((value1>=1035500) && (value1<=1036999))
jean=23.2;
else if((value1>=1034000) && (value1<=1035499))
jean=23.3;
else if((value1>=1032000) && (value1<=1033000))
jean=23.4;
else if((value1>=1030000) && (value1<=1031999))
jean=23.5;
else if((value1>=1028999) && (value1<=1029999))
jean=23.6;
else if((value1>=1027500) && (value1<=1028998))
jean=23.7;
else if((value1>=1026500) && (value1<=1027499))
jean=23.8;
else if((value1>=1026000) && (value1<=1026499))
jean=23.9;
else if((value1>=1025000) && (value1<=1025999))
jean=24.0;
else if((value1>=1024000) && (value1<=1024999))
jean=24.1;
else if((value1>=1022500) && (value1<=1023999))
jean=24.2;
else if((value1>=1021500) && (value1<=1022499))
jean=24.3;
else if((value1>=1021000) && (value1<=1021499))
jean=24.4;
else if((value1>=1020000) && (value1<=1020999))
jean=24.5;
else if((value1>=1018500) && (value1<=1019999))
jean=24.6;
else if((value1>=1018200) && (value1<=1018499))
jean=24.7;
else if((value1>=1018000) && (value1<=1018199))
jean=24.8;
else if((value1>=1017500) && (value1<=1017999))
jean=24.9;
else if((value1>=1017000) && (value1<=1017499))
jean=25.0;
/*else if((value1>=1016500) && (value1<=1016999))
jean=25.1;
else if((value1>=1016000) && (value1<=1016499))
jean=25.2;
else if((value1>=1015500) && (value1<=1015999))
jean=25.3;
jean=25.4;
else if((value1>=1014500) && (value1<=1014999))
jean=25.5;
else if((value1>=1014000) && (value1<=1014499))
jean=25.6;
else if((value1>=1013500) && (value1<=1013999))
jean=25.7;
else if((value1>=1012500) && (value1<=1012999))
jean=25.9;
else if((value1>=1012000) && (value1<=1012499))
jean=26.0;
else if((value1>=1013000) && (value1<=1013499))
jean=25.8;
else
printf(lcd_putc,"\fConnect Probe");
delay_ms(1500);
void main(void)
set_tris_c(0xff);
set_tris_b(0x00);
lcd_init();
delay_us(200);
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_INTERNAL);
set_adc_channel(0);
adc_value = read_adc();
volts = ((float)(adc_value * 500)/1023.0);
delay_ms(400);
delay_ms(1500);
printf(lcd_putc, "\fWELCOME");
delay_ms(1500);
break;
while(true)
if((input(PIN_C5)==0))
final();
if(input(PIN_C5)==0)
delay_ms(150);
lcd_gotoxy(7,1);
printf(lcd_putc,"\fWait");
delay_ms(2500);
printf(lcd_putc,"\f%3.1f",volts);
printf(lcd_putc,"\°C");
delay_ms(2500);
lcd_gotoxy(7,1);
printf(lcd_putc,"\f%2.1f"jean);
printf(lcd_putc,"\%%");
delay_ms(3500);
if(input(PIN_C4)==0)
printf(lcd_putc,"\fSinusoidal");
delay_ms(2000);
if(input(PIN_C1)==0)
printf(lcd_putc,"\fSquare");
delay_ms(2000);
#DEVICE ADC=10
#include "lcd.c"
#define ka PIN_C3
#use fast_io(c)
#use fast_io(b)
#use fast_io(a)
void tempdisplay();
void kagaba();
void final();
float voltsf,volts;
float period;
double jean;
float value;
double value1;
void final(void)
jean=7.2;
jean=7.3;
jean=7.4;
jean=7.5;
jean=7.6;
jean=7.7;
jean=7.8;
jean=7.9;
jean=8.0;
jean=8.1;
jean=8.2;
jean=8.3;
jean=8.4;
jean=8.5;
jean=8.6;
jean=8.7;
jean=8.9;
jean=9.0;
jean=9.1;
jean=9.2;
jean=9.3;
jean=9.4;
jean=9.5;
jean=9.6;
jean=9.7;
jean=9.8;
jean=9.9;
jean=10;
jean=10.1;
jean=10.2;
jean=10.3;
jean=10.4;
jean=10.5;
jean=10.6;
jean=10.7;
jean=10.8;
jean=10.9;
jean=10.9;
jean=11.0;
jean=11.1;
jean=11.2;
jean=11.3;
jean=11.4;
jean=11.5;
jean=11.6;
jean=11.7;
jean=11.8;
jean=11.9;
jean=12.0;
jean=12.1;
jean=12.2;
jean=12.3;
jean=12.4;
jean=12.5;
jean=12.6;
jean=12.7;
jean=12.8;
jean=12.9;
jean=13.0;
jean=13.1;
jean=13.2;
jean=13.3;
jean=13.4;
jean=13.5;
jean=13.6;
jean=13.7;
jean=13.8;
jean=13.9;
jean=13.9;
jean=14.0;
jean=14.1;
jean=14.2;
jean=14.3;
jean=14.4;
jean=14.5;
jean=14.6;
jean=14.7;
jean=14.8;
jean=14.9;
jean=15.0;
jean=15.1;
jean=15.2;
jean=15.3;
jean=15.4;
jean=15.5;
jean=15.6;
jean=15.7;
jean=15.8;
jean=15.9;
jean=16.0;
jean=16.1;
jean=16.2;
jean=16.3;
jean=16.4;
jean=16.5;
jean=16.6;
jean=16.7;
jean=16.8;
jean=16.9;
jean=17.0;
jean=17.1;
jean=17.2;
jean=17.3;
jean=17.4;
jean=17.5;
jean=17.6;
jean=17.7;
jean=17.8;
jean=17.9;
jean=18.0;
jean=18.1;
jean=18.2;
jean=18.3;
jean=18.4;
jean=18.5;
jean=18.6;
jean=18.7;
jean=18.8;
jean=18.9;
jean=19.0;
jean=19.1;
jean=19.2;
jean=19.2;
jean=19.3;
jean=19.4;
jean=19.5;
jean=19.6;
jean=19.7;
jean=19.8;
jean=19.9;
jean=20.0;
jean=20.1;
jean=20.2;
jean=20.3;
jean=20.4;
jean=20.5;
jean=20.6;
jean=20.7;
jean=20.8;
jean=20.9;
jean=21.0;
jean=21.1;
jean=21.2;
jean=21.3;
jean=21.4;
jean=21.5;
jean=21.6;
jean=21.7;
jean=21.8;
jean=21.9;
jean=22.0;
jean=22.1;
jean=22.2;
//jean=22.3;
jean=22.4;
jean=22.5;
jean=22.6;
jean=22.7;
jean=22.8;
jean=22.9;
jean=23.0;
jean=23.1;
jean=23.2;
jean=23.3;
jean=23.4;
jean=23.5;
jean=23.6;
jean=23.7;
jean=23.8;
jean=23.9;
jean=24.0;
jean=24.1;
jean=24.2;
jean=24.3;
jean=24.4;
jean=24.5;
jean=24.6;
jean=24.7;
jean=24.8;
jean=24.9;
jean=25.0;
jean=25.1;
jean=25.2;
jean=25.3;
jean=25.4;
jean=25.5;
jean=25.6;
jean=25.7;
jean=25.9;
jean=26.0;
jean=25.8;
else
delay_ms(1500);
void main(void)
set_tris_c(0xff);
set_tris_b(0x00);
lcd_init();
delay_us(200);
set_adc_channel(0);
delay_ms(400);
delay_ms(1500);
delay_ms(1500);
break;
while(true)
final();
delay_ms(150);
lcd_gotoxy(7,1);
delay_ms(2500);
delay_ms(2500);
lcd_gotoxy(7,1);
delay_ms(3500);
delay_ms(2000);
delay_ms(2000);
