interfacing encoder SSI output to RS-422 port...
ssankurathri
Full Member level 3
Full Member level 3
Bangalore
I am new to working on these protocols. I have couple of encoders which provide SSI output. I need to interface these outputs to RS-422 port of micro. Can I use any RS-422 transceiver to do this?
what kind of interface do I need to use?
Any guidance on this would be much helpful.
Regards,
skr
Thank you. Can we change this SSI to UART? Any modules available to do this?
Regards,
skr
The encoder implements a synchronous slave interface, clock input and data output. To convert it to UART, you'll need a logic device with some "intelligence", e.g. a microcontroller.
