niyati doshi
Newbie level 2
Hi eveyone,
I need a help in programming for DHT11 interfacing with PIC16F877A.
I need to transfer my data on Rx, Tx pin of micro controller.
There's a code for on interfacing with LCD but whenever i am modifiying the code for USART my data is not coming on Rx Tx pin.
Please help me with the code.
CODE:
char message1[] = "Temp = 00.0 C";
char message2[] = "RH = 00.0 %";
unsigned short TOUT = 0, CheckSum, i, Check;
unsigned short T_Byte1, T_Byte2, RH_Byte1, RH_Byte2;
unsigned short Data, DataDir, heck ;
char usart_rd;
void StartSignal(){
DataDir = 0;
Data = 0;
Delay_ms(25);
Data = 1;
Delay_us(30);
DataDir = 1;
unsigned short CheckResponse(){
TOUT = 0;
TMR2 = 0;
T2CON.TMR2ON = 1;
while(!Data && !TOUT);
if (TOUT) return 0;
else {
TMR2 = 0;
while(Data && !TOUT);
if (TOUT) return 0;
else {
T2CON.TMR2ON = 0;
return 1;
unsigned short ReadByte(){
unsigned short num = 0, t, i;
DataDir = 1;
for(i=0;i<8;i++)
while(!Data);
TMR2 = 0;
T2CON.TMR2ON = 1;
while(Data);
T2CON.TMR2ON = 0;
if(TMR2 > 40) num |= 1<<(7-i);
return num;
void interrupt(){
if(PIR1.TMR2IF){
TOUT = 1;
T2CON.TMR2ON = 0;
PIR1.TMR2IF = 0;
void main(){
PORTA = 0b11111111;
PORTB = 0;
TRISB = 0;
PORTC = 0;
TRISC = 0;
PORTD = 0;
TRISD = 0;
CMCON = 7;
INTCON.GIE = 1;
INTCON.PEIE = 1;
PIE1.TMR2IE = 1;
T2CON = 0;
PIR1.TMR2IF =0;
TMR2 = 0;
Usart_Init(9600);
Delay_ms(100);
LCD_Init(&PORTD); // Initialize LCD connected to PORTB
LCD_Cmd(LCD_CLEAR); // Clear display
LCD_Cmd(LCD_CURSOR_OFF); // Turn cursor off
do {
Delay_ms(1000);
StartSignal();
heck = CheckResponse();
if (!check) {
Lcd_Cmd(Lcd_CLEAR);
Lcd_Out(1, 1, "No response");
Lcd_Out(2, 1, "from the sensor");
else{
RH_Byte1 = ReadByte();
RH_Byte2 = ReadByte();
T_Byte1 = ReadByte();
T_Byte2 = ReadByte();
CheckSum = ReadByte();
if (CheckSum == ((RH_Byte1 + RH_Byte2 + T_Byte1 + T_Byte2) & 0xFF))
message1[7] = T_Byte1/10 + 48;
message1[8] = T_Byte1%10 + 48;
message1[10] = T_Byte2/10 + 48;
message2[7] = RH_Byte1/10 + 48;
message2[8] = RH_Byte1%10 + 48;
message2[10] = RH_Byte2/10 + 48;
message1[11] = 223;
Lcd_Cmd(Lcd_CLEAR);
Lcd_Out(1, 1, message1);
Lcd_Out(2, 1, message2);
usart_rd = message1;
else{
Lcd_Cmd(Lcd_CLEAR);
Lcd_Out(1, 1, "Checksum Error!");
Lcd_Out(2, 1, "Trying Again ...");
}while(1);
TRISC = 0;
PORTC = 0;
UART1_Init(9600);
Delay_ms(100);
while(1){
if(UART1_Data_Ready()){
usart_rd = UART1_Read();
UART1_Write(usart_rd);
CODE:
char usart_rd;
void StartSignal(){
DataDir = 0;
Data = 0;
Delay_ms(25);
Data = 1;
Delay_us(30);
DataDir = 1;
TOUT = 0;
TMR2 = 0;
T2CON.TMR2ON = 1;
if (TOUT) return 0;
else {
TMR2 = 0;
if (TOUT) return 0;
else {
T2CON.TMR2ON = 0;
return 1;
DataDir = 1;
for(i=0;i<8;i++)
while(!Data);
TMR2 = 0;
T2CON.TMR2ON = 1;
while(Data);
T2CON.TMR2ON = 0;
return num;
void interrupt(){
if(PIR1.TMR2IF){
TOUT = 1;
T2CON.TMR2ON = 0;
PIR1.TMR2IF = 0;
void main(){
PORTA = 0b11111111;
PORTB = 0;
TRISB = 0;
PORTC = 0;
TRISC = 0;
PORTD = 0;
TRISD = 0;
CMCON = 7;
INTCON.GIE = 1;
INTCON.PEIE = 1;
PIE1.TMR2IE = 1;
T2CON = 0;
PIR1.TMR2IF =0;
TMR2 = 0;
Usart_Init(9600);
Delay_ms(100);
do {
Delay_ms(1000);
StartSignal();
if (!check) {
Lcd_Cmd(Lcd_CLEAR);
else{
message1[11] = 223;
Lcd_Cmd(Lcd_CLEAR);
else{
Lcd_Cmd(Lcd_CLEAR);
}while(1);
TRISC = 0;
PORTC = 0;
UART1_Init(9600);
Delay_ms(100);
while(1){
