interfacing betweem rs232 and 8051
shalini sharma
Newbie level 2
Newbie level 2
i have a problem....pls help me frnds....
firstly i want to type my name(shalini)...after that it should gets stored in the buffer..
and finally i receive "hello shalini"
plz help me...by using keil software....:|
first elaborate a bit more, which stuff you will use, where you want to input your name, and where you want it to be displayed.
Do you want to type it at your PC and display it on 16x2 LCD connected with your 8051 ucontroller?
i will communicate through hyper terminal...on the pc.....i type my name from keyboard of pc in hyper terminal and then it displayed hello shalini on the hyper terminal screen on the pc.....
i m using keil software for this....i want the code for this program...plzz
well entire code is not a good educational discussion, however you should try yourself, and if face any problem, you can ask. and by the way it is simplest serial communication.
best of luck
