David_
Advanced Member level 2
Hello.
I've bought a student license for matlab and the main thing to explore was interfacing a µC with matlab/simulink to be used as a platform for ADC/DAC testing and a lot of other cool things.
But after installing all support packages and trying to connect ta arduino(have tried Uno, Mega and Due) an error occurse in windows.
when trying to run:
a = arduino('com5','Due','TraceOn',true)
then matlab says:
Updating server code on Arduino Due (COM5). Please wait.
& then
windows responds with a programerror pop-up and in the top of the pop-up it says:
arm-none-eabi-gcc.exe - programfel(swedish for programerror)
and in the window(translated from sweidish) it says:
The program could not start correctly(0x0000142)
when that window get closed matlab proceeds to show:
EDU>> a = arduino('com5','Due','TraceOn',true)
Vendor returned error messages:
C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/tools/g++_arm_none_eabi/bin/arm-none-eabi-gcc
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/system/libsam"
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/system/CMSIS/CMSIS/Include"
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/system/CMSIS/Device/ATMEL"
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/cores/arduino"
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/cores/arduino/USB"
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/variants/arduino_due_x"
-c -g -Os -w -ffunction-sections -fdata-sections -nostdlib --param
max-inline-insns-single=500 -Dprintf=iprintf -mcpu=cortex-m3
-DF_CPU=84000000 -DARDUINO=156 -D__SAM3X8E__ -mthumb -DUSBCON
-DARDUINO_ARCH_SAM
C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/cores/arduino/WInterrupts.c
-o C:/Users/David/AppData/Local/Temp/ArduinoServer/WInterrupts.c.o
cs-make: ***
[C:/Users/David/AppData/Local/Temp/ArduinoServer/WInterrupts.c.o] Error
-1073741502
and with the uno:
EDU>> a = arduino('com4','Uno','TraceOn',true)
Updating server code on Arduino Uno (COM4). Please wait.
C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/tools/avr/bin/avr-gcc
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/avr/libraries/Wire/utility"
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/avr/cores/arduino"
-I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/avr/variants/standard"
-mmcu=atmega328p -MMD -fno-exceptions -ffunction-sections -fdata-sections
-g -Os -w -D"F_CPU=16000000" -DUSB_VID=0x2341 -DUSB_PID=0x0043
-DARDUINO=156 -DARDUINO_ARCH_AVR -c -x none
C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/avr/cores/arduino/hooks.c
-o C:/Users/David/AppData/Local/Temp/ArduinoServer/hooks.c.o
make: *** [C:/Users/David/AppData/Local/Temp/ArduinoServer/hooks.c.o]
Error -1073741502
only the pop-up says "avr-gcc.exe"
All I can find out is that 0x0000142 is a general error that can occure in widows but I am far to ignorant in how widows works to be able to solve this, and I can't seam to find a suiteble place to ask.
I will call matlab support as well and see what they say.
does these messages tell anyone what the problem is?
when trying to run:
then matlab says:
& then
-DARDUINO_ARCH_SAM
cs-make: ***
-1073741502
and with the uno:
Error -1073741502
