Interfacing 16 bits SerDes IC to PC (USB).
ril
Newbie level 2
Newbie level 2
Malaysia
Hi All,
I'm making a transceiver using a SerDes IC NATIONAL SEMICONDUCTOR - DS92LV16TVHG..
I have a problem in interfacing this IC with USB port in my laptop so that I can make a data communication from 1 PC to another PC by using that transceiver.
The IC has 16 bits parallel input and 16 bits parallel output to be interfaced with PC.
Here is the link for the datasheet.. **broken link removed**
Can you help me or give me solution from the problem that I face?
Thanks in advance..
