ajit_nayak87
Member level 5
Dear all,
I am trying to migrate PIC16F886 Mplab V8.86 to PIC18F24K40 with MPLAB X v3.61.
The Pin configration of Both IC are same. I have working code on PIC16F886 with DS1307. I am trying to communicate DS1307 with PIC18F24K40. I tried Use same syntax .I found slave wont send any acknowledged when master send request.
For PIC18F24K40 using internal Oscilator with 8Mhz clock frequency. I am testing code in I2C slave mode. I could see start bit , followed by slave address. As per Ds1307 datasheet i need to read acknowledge , but i am receiveing no ack signal from device. Kindly help any solution for below issue.
Code C (Mac) - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 #include "mcc_generated_files/mcc.h" #include "mcc_generated_files/i2c1.h" I2C1_MESSAGE_STATUS status = I2C1_MESSAGE_PENDING; # define LED RC7 unsigned int i; unsigned int count; unsigned int x; unsigned short sec; unsigned short min; unsigned short hour; unsigned short date; unsigned short month; unsigned short year; unsigned short day; unsigned short int temp=0; unsigned short r_data; #define Seg1 0x01 #define Seg2 0x02 #define Seg3 0x04 #define Seg4 0x08 #define Seg5 0x10 #define Seg6 0x20 #define DS1307_RETRY_MAX 100 // define the retry count #define DS1307_ADDRESS 0xD0 // slave device address #define SLAVE_I2C_GENERIC_RETRY_MAX 100 #define SLAVE_ADDRESS 0X68 unsigned char SSP_Buffer[16]; unsigned int PT_MSG_STATUS; void SetSeg(unsigned short data, unsigned short segno) { switch(data) { case 0: PORTB = 0x3F; break; case 1: PORTB = 0x06; break; case 2: PORTB = 0x5B; break; case 3: PORTB = 0x4F; break; case 4: PORTB = 0x66; break; case 5: PORTB = 0x6D; break; case 6: PORTB = 0x7D; break; case 7: PORTB = 0x07; break; case 8: PORTB = 0x7F; break; case 9: PORTB = 0x6F; break; default : PORTB = 0X00; break; } if(segno==1) { PORTA = Seg4; } if(segno==2) { PORTA = Seg3; } if(segno==3) { PORTA = Seg2; } if(segno==4) { PORTA = Seg1; } } unsigned int bcdtodecimal(unsigned int bcd) { unsigned int decimal; decimal = (((bcd & 0xF0) >> 4) * 10) + (bcd & 0x0F); return decimal; } void ds1307_write(unsigned char addr ,unsigned char data) { SSP1CON2bits.SEN =1; //SSP1BUF = 0XD0; //slave address(address of ds1307) + write bit SSP1BUF =0X68; SSP1BUF =addr; SSP1BUF = data; SSP1CON2bits.PEN =1; //stop bit } unsigned int ds1307_read(unsigned char addr) { SSP1CON2bits.RSEN =1; //SSP1BUF =0XD0; //slave address(address of ds1307) + write bit; SSP1BUF =0X68; SSP1BUF =addr; SSP1CON2bits.RSEN =1; //SSP1BUF =0XD1; //slave address(address of ds1307) + read bit; SSP1BUF =0X69; SSP1CON2bits.RCEN =1; SSP1CON2bits.ACKDT=1; SSP1CON2bits.ACKEN =1; SSP1CON2bits.PEN=1; x = SSP1BUF; return (x); } void SetDateTime() { ds1307_write(0X00,0x03); ds1307_write(0X01,0X07); ds1307_write(0X02,0X00); ds1307_write(0X3,0X01); ds1307_write(0X04,0x07); ds1307_write(0X5,0X08); ds1307_write(0X6,0X10); } void GetDateTime() { sec = ds1307_read(0X00); sec=bcdtodecimal(sec); min = ds1307_read(0X01); min = bcdtodecimal(min); hour = ds1307_read(0X02); hour=bcdtodecimal( hour); day= ds1307_read(0X03); day = bcdtodecimal(day); date= ds1307_read(0X04); date=bcdtodecimal(date); month= ds1307_read(0X05); month = bcdtodecimal( month); year= ds1307_read(0X06); year= bcdtodecimal(year); } void Blink_Count() { if(PIR0bits.TMR0IF == 1) { PIR0bits.TMR0IF =0; count=count+1; if(count>=12) { LED=!LED; count=0; } } } void I2C_Intialize() { SSP1CON1bits.CKP=1; SSP1STAT=0X80; SSP1CON1 = 0x38; SSP1CON3 = 0x00; SSP1ADD = 0x27; } void main(void) { // Initialize the device SYSTEM_Initialize(); I2C_Intialize(); uint8_t write_value; uint8_t *pt_write_value; pt_write_value = &write_value; uint8_t read_values; uint8_t write_values[2]; //create a two-byte array write_values[0] = 0x88; // 0x80 write_values[1] = 0x89; // 0x01 SSP1CLKPPS = 0x0E; //RB6->MSSP:SCL; SSP1DATPPS = 0x0C; //RB4->MSSP:SDA; RB6PPS = 0x10; //RB6->MSSP:SCL; RB4PPS = 0x11; //RB4->MSSP:SDA; SetDateTime(); I2C1_MasterWrite(write_values,1,SLAVE_ADDRESS,&status); while (1) { GetDateTime(); SetSeg(min/10,4); SetSeg(min%10,3); SetSeg(sec/ 10,2); SetSeg(sec%10,1); // I2C1_MasterRead(read_values,1,SLAVE_ADDRESS,&status); // sec=read_values; } }
