Interface CO sensor to Microcontroller using PIC Basic programming
jepateda
Junior Member level 3
philippines
guys,, help how to program CO sensor to MCU using PIC Basic,, i want to have three level in three ranges in Parts per million of CO sensor,, if you have same project please help me,, after having levels,, it must be sent through SMS,, please help,,
use TGS2442 or TGS5042 Carbon monoxide (50-1000ppm) sensor from figaro
yes,, i have now the sensor,, i need help in how to send the level via sms using pic, mobile phone integrated to pc,
thnks,, help will really be apprecited
    V
can you help me,, i will be using now GSM modem,, where can i buy it???
what part in tgs5042 is used to detect CO and do i need to supply any voltage to the sensor??? how can i calibrate the output voltage???
please help... thanks,,,
hi friend,
i too doing similar proj wat u are doing.i m going to monitor some gases like CO , non volatile compounds,etc.can u help me how to interface PIC with CAN protocol.if u have coding related to my proj,try to send.plz help me to finish my proj,,
Hj,
I'am programming for CO detector sensor TGS2442 with Atmega16.If you had programming with PIC,
pls send me your code so i can see
Thanks u,
