inter clock & intra clock
designer_ec
Member level 4
Member level 4
What is the difference between inter clcok and intra clock,and also what are the application of inter clcok and intra clock.At which analysis we use these.Pls explain detail about this.
There are a number of timing constraints that apply to flip-flops (or other elements) that are all relative to the same clock signal. These are called intra-clock constraints, or timing, etc.
Sometimes there are timing paths or constraints that cross from one clock to another. These are called inter-clock constraints, or timing.
For example, you can have a skew defined for one clock (intra-clock skew) or you can define the skew between two or more different clocks (inter-clock skew)
