bkelly
Member level 1
Windows 7, IAR Embedded workbench, Micrium uC/0S-iii, and Micrium uC/Probe
The IAR is working with the Micrium eval board uC/Eval-STM32F107. The Micrium book shows the use of their uC/Probe. The book seems to indicate that their uC/Probe runs in conjunction with IAR Workbench. From what I see, they are two independent products.
I start the first example project and get it running. Micriums uC/Probe can be started separately, but it does not detect that IAR is running or that the eval board is present and running.
Does anyone know how to integrate Micrium uC/Probe with IAR Workbench. Or maybe, can it be done?
Just in case, if you have the Micruim book "uC/OS-III", hard copy or pdf version, page 776.
EDIT, 2 April 2012
I now suspect these two don't integrate at all, but operate separately. After more work I have found that the Probe program causes IAR to crash, then it stops working. If I start IAR, download and start the app on the eval board, then close IAR, Probe can be started and appears work fine. I suspect that is not the way it should work. I will continue working on this.
EDIT, 2 April 2012
