Vicountboo
Newbie level 5
Hi
Can anyone make sense of this question :? ? It has to do with a "classic" three design instrumentation amplifier.
"Assume that a 100Hz sinusoidal differential voltage, (V1-V2), of magnitude 10mV p.p. is input to your circuit. The differential voltage is subject to a common-mode component of 200mV p.p. at 50Hz, arising from power-line interference.
If Measurements performed on a practical implementation of the amplifier, constructed using ±5% tolerance resistors, show the circuit to have a Common Mode Rejection Ratio (CMRR) of 65bB at 50 Hz, calculate the magnitude of the 50Hz component of the output signal."
Thanks
Thanks
