instnciate a VHDL module into a verilog hierarchy help!!!!!!
hawk
Member level 4
Member level 4
Hi fox ,
Need your help ASAP to instanciate a vhdl module into a verilog
Hierarchy.
Please help how to do this.
Should i do this same as a regular verilog instanciation?????
Hawk. :cry:
Re: instnciate a VHDL module into a verilog hierarchy help!!
hawk said:
Hi fox ,
Hierarchy.
Hawk. :cry:
Hello,
Read before the verilog source, the VHDL module can be instanciated....I think...
Good luck! :wink:
Hi
How should i instance the vhdl?
should i use vhdl syntax of instanciation in the verilog source ?
or should i use verilog syntax of instanciation of the vhdl module
in the verilog source ????
still need help.
regards,
hawk.
Re: Hi
still need help.
regards,
hawk.
U have to instanciate the VHDL module like any other verilog module:
vhdl_module_name instance_name(port_instanciantion);
I hope this helps.
hi
This is not working.
still need help,
Hawk.
Re: hi
still need help,
Hawk.
Well, depends on what synthesys tool u are using, I guess...
I use DC.
So, the order is to be like this:
-assume the the vhdl module is named link_core;
-in the verilog file, instanciate the module:
link_core instance_link_core(.input1(in1), ....);
-I read the vhdl file in which i wrote the code;
-I read the verilog file and link the design and it should work.....
If not, give more info, pls.
Regards....
Hi
How should i do this in the simulation process not in the synth'??
I use nc sim.
how should i tell novas/NC to read it correctly?
Regards,
Hawk.
Hi
What do you meen for link the design???
in the simulation process.
Hawk.
Re: Hi
I use nc sim.
Regards,
Hawk.
I'm not sure if nc sim reads verilog and vhdl together..... :(
I know ModelSim does that....
